Central locking system
So, I've had the recurring and worsening:
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
These pumps are prone to breaking and I've had this problem since I bought the car. Today I replaced it with a relatively cheap lock pump on Ebay ($230/new).
FYI: The original pump # is 8LO 862 257 B, I called the dealer and he quoted me $560 for a new 8LO 862 257 N pump. That model is in the S4's and it looks completely identical to the old model.
It took me about 30 minutes total to remove and replace, pretty easy. Unfortunately, the problem is still there. Has anyone tracked down and fixed a leak? Any tips? Is there a certain area that is more likely to be leaking?
Thanks
Tony
1 Fault Found:
Thanks
Tony
Here's the article I read about the broken pumps.<ul><li><a href="https://forums.audiworld.com/s4/msgs/1817706.phtml">https://forums.audiworld.com/s4/msgs/1817706.phtml</a</li></ul>
Turbo_Anarchy
Audi Original "S" Cars
03-05-2007 10:08 AM
sangelini@gmail.com
12-02-2006 03:58 PM
f3d
09-26-2005 02:28 PM
