Check engine light came on the other day. Any help to understand is appreciated. TIA!
VAG-COM Version: Release 704.1
Data version: 20071016
Thursday,06,March,2008,18:12:13:18301
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
VIN: WAUFL54DXYN012860
Address 01: Engine Labels: None
Part No: 4D0 907 560 AL
Component: 4.2L V8/5V G 0001
Coding: 06753
Shop #: WSC 01115
WAUFL54DXYN012860 AUZ7Z0Y1366186
9 Faults Found:
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16692 - Cylinder 8: Misfire Detected
P0308 - 35-10 - - - Intermittent
16691 - Cylinder 7: Misfire Detected
P0307 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
16690 - Cylinder 6: Misfire Detected
P0306 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16816 - Main Catalyst; Bank 2: Efficiency Below Threshold
P0432 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 35: Centr. Locks Labels:
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 56: Radio Labels: None
Part No: 4D0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
02
Coding: 06753
Shop #: WSC 01115
9 Faults Found:
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
00-00 - -
Step two- put one or two bottles of Techron in the tank at your next fill up.
Step three- repost any codes that return within 1 week.
and the misfire was gone.
I immediately followed PaulW's suggestion, ordered a fuel filter and replaced it two days ago.
The car is a 99 with 95K now and it had a factory fuel filter.<ul><li><a href="https://forums.audiworld.com/a8/msgs/157656.phtml">https://forums.audiworld.com/a8/msgs/157656.phtml</a</li></ul>
i also had this come up the other day, i've only had my A8 a few months. how do you clear the codes? any help is appreciated!
franklinstower
10
03-06-2007 02:21 PM
