check engine light (MIL)
Drove to the grocery store today (3miles round trip) came home parked the car in the driveway. About five hours later, started the car to put in the garage. The car was idling rough. Put it in the garage, and still rough so I gave the gas pedal a little tap hoping that it would clear the rough idle, but the check engine light came on and started flashing. The light flashed for about ten seconds and then went steady. Continued to idle rough, the car was even shaking. I shut the car off, and re-started still rough and the light came on. What is going on? Thanks a lot!
Doug G.
1997 A8Q 110K
Doug G.
1997 A8Q 110K
in your gas tank. Follow directions on the bottle. You can get it anywhere from Walmart to Pep Boys. I've had the same problem. Can't find all the discussions we've have had about this on this forum. Good luck.
In my case this problem ocurred when starting the engine a long time after driving it.
does it matter that I put the highest octace gas in my car all the time. I thought the reason I put premium in my car is so I don't have to use additives.
Doug G.
97 A8
Doug G.
97 A8
You won't be able to tell if that's the problem without vag-com, but a lot of A8's have this problem with 100K miles or so....it's not hard to believe.
I would put some injector cleaner in the tank and drive it and see what happens.
FLYINGNUGGETT
11-10-2003 03:34 AM
auDD
02-26-2002 08:01 PM
Gorobei
11-14-2000 09:26 AM
