Chrome moulding around side windows tarnished
Hi A8 folks: I have a 2.7T A6 and the chrome moulding around side windows is tarnished, as well as the chrome moulding on the bottom of the trunk lid. I think there is some type of plastic coating on top of the chrome. Is there any type of polish / cleaner that someone has had sucess with to restore the original shine? Thanks in advance, Drew Hill
May not be polished sez the Audi manual. (In fact they say polishing (or pressure) causes the 'milky' tarnishing). So don't expect too much... However, if you come to the point of buying new trim anyway, there's no harm in trying first. But I think you'll need to polish all coating off (and then maybe re-coat). A rag and some polish won't do it though I'm afraid.
I am going to black out the entire chrome trims in my 97 Audi. I have found a product called "Black Out Tape" which is flexible enough to apply but fade and scratch resistant. Permanent bonding also. I will post pic after this weekend.
<i>
Technical problem solution
Problem description: aluminum eloxy ornaments matt, discolored, milky.
Cause: the silver-colored ornaments and trim of the Audi models consist of pure aluminium (aluminium 99.9). The use of aluminum at and in the vehicle corresponds to the Audi philosophy and rises from the environmental protection thought, since during the production of conventional chrome trim, which environment is loaded unusually highly with pollutants and environmental poisons. The disposal of trim from pure aluminium is relatively problem-free, contrary to chromium-plated ornaments. During the production of aluminum eloxy borders the aluminum borders are first highly polished. Afterwards the aluminum border receives an eloxy protective layer by anodic oxidation. This anodized coat is a corrosion protection layer and has a thickness between 8 - 10 µm. This anodized coat is transparent. The anodized coat is relatively brittle and corresponds in the brittle for instance a ceramic(s) layer, i.e. if a border is bent it will develop fine hair-cracks on the border and the protective layer is thereby damaged. For the cleaning of the ornaments no polishing agents or alkaline and/or acid cleaning agents may be used, since these can damage the anodized coat. Please you consider to be absolutely used the processing references of the maintaining and cleaning agents for the vehicle preparation (like e.g. industrial cleaners). In carwash streets alkaline intensive cleaners are also used. Since these cleaners are highly concentrated, it is necessary to pay attention to a sufficient dilution with water. Therefore you must make sure that cleaning agents on the vehicle are rinsed off completely with water. This is important particularly on hot summer days, since the water dries relatively fast and residue parts of the cleaning agent remain sticking to the finish and cause damage. If the protective layer is damaged it comes to the white corrosion with aluminum (border starts to turn matte or is discoloured, milky). For the care of the aluminum eloxy trim please consider the care references in the manual of the vehicle.
Solution: replace damaged trim by new part.
</i>
That's a (translated) bit from the repair manual.
Also found a linky or two that may offer a solution.
<a href="http://www.irinfo.com/polish/html/polish.html">The Swift Method</a>
<a href="http://www.californiacustom.net/products/aluminum_deoxidizer/">Aluminum Deoxidizer</a>
</i>
