Clear Corner Mod - How do I get the reflector out now?
Okay, I'm stumped...it appears the clear plastic lens is connected to the frame with some type of silicone.....do I separate the two or do I somehow get the orange piece out by magic?
<img src="http://pictureposter.audiworld.com/22012/sm_dsc_6379.jpg">
Double check with TerminA8r, but I think the orange reflector ----->
gets snipped into small pieces....small enough to fit out of the hole for the bulb once it is loosened from the housing with low profile snips/cutters. Essentially it gets reflector needs to be destroyed.
Double check with those who have been there first.
Re: Clear Corner Mod - How do I get the reflector out now?
Any chance you could post a few pics of the back side of your headlight? Specifically the areas where the headlight and self leveling harness plugs in.
thanks
thanks
You can't get access to it, I will try to separate the two pieces
Can't believe you guys haven't done a detailed write up with pictures yet!
Paging Jim 03-S8 and MPollan...
They just did this about a month ago. Found this thread, but have to run out so I can't check them all; it's gotta be in here somewhere...<ul><li><a href="https://forums.audiworld.com/a8/msgs/159939.phtml">Surgery Procedure</a></li></ul>
Got it
I would suggest that you almost get a set of three plastic tire irons for a bicycle....I used a trim removal tool and then a small screw driver to keep the parts apart while separating the whole thing.
I will write up a procedure for audipages......it looks good, but I wish I could of got the inside cleaner (the shiny part) before I put it back together. It looked clean at the time.
I wouldn't try this without a heat gun. Looks very cool. Got the clear bulbs also.
<img src="http://www.audipages.com/upgrades/sm_DSC_6430.JPG">
<img src="http://www.audipages.com/upgrades/sm_DSC_6441.JPG">
There is only one harness on the 01's
I don't know if it was you, but somebody said that they had two sets of wires for an 02....I looked them up, and the 01 and 02/03 are different as I recall.
<img src="http://www.audipages.com/upgrades/sm_DSC_6419.JPG">
<img src="http://www.audipages.com/upgrades/sm_DSC_6425.JPG">
<img src="http://www.audipages.com/upgrades/sm_DSC_6426.JPG">
