climate control smells like a stable! 97/A8/4.2/Q
I had my air compressor replacad under Audi assured warranty and it has terrible smell as long as I am driving . Before it was only 10-20 seconds.Any ideas why?
Thanks !
Thanks !
For now, you probably only have stagnant water accumulating in the system, expect to find soggy carpets next. The audipages link is a procedure for clearing the drains.<ul><li><a href="http://www.audipages.com/Tech_Articles/heatac/exaporatordrains.html">Unclogging the drains</a></li></ul>
Since the A/C normally runs unless ambient temp is below ~5 oC, the fresh water supply every day is probably enough to keep it alive and smelling. Perhaps it'll take an extended cold weather spell, or a few months in econ mode during the Winter, to finally kill it and the smell. I don't think I'm at the point where I'd recommend spraying a fungicide into the air inlet.
into the cooling ducts where you remove the orange plugs to blow out the system? Or, how about running the heater on high for a while (with the windows open) and dry out the system- fungi need moisture to survive, and if you dry the system out thoroughly it my kill it.
...after replacing the chewed side panel and seat belts with new ones, I soaked the whole interior in Febreeze and let it dry in direct sunlight.
It worked very well, and I've only had to re-Febreeze the one area that they actually lived in a couple of times.
Febreeze worked for musty mouse ****, it will probably work on your interior.
I'm new but have lurking for awhile. I have a sideline detail business and can tell you that Einszett, a German company whose products I use, has a product that will take care of the smell which is probably coming from the a/c condenser. Really simple to use, but the dealer will charge you a serious amount of money to fix. Go look at the Einszett North American site and you can probably purchase direct. Their site is www.einszettna.com.
Good luck,
Sam
Good luck,
Sam
Studly_1
Audi allroad
01-16-2005 07:22 AM
dimA4
11-28-2004 10:20 AM
