Clunking front...leaking subframe bush
#12
You're shattering my reality again
40V motors have 2 stage solenoid controlled hydraulic (fluid chambers) mounts, which ETKA calls "electric hydro-mounts".
On previous 32V motors, ETKA calls them "hydro-mounts".
NOT fluid filled at all??!! Why are they called "hydro"? ...Water? ...not oil? ...solid...or what?
1999 printing of info for US Audi mechanics about the 40V engine in A8:
#13
Thanks for the tip, I'll have to have a look and track the source of the oil down. Its too thick for engine oil. I've had plenty of cars with oil filled engine mounts...are these seriously solid mounts? A quick check of the power steering oil level will no doubt tell me a lot
EDIT: Cheers Sam ...man these things are like Space Shuttles when you get into them
#14
But. Tozo is the dude who'd know...he works on all years professionally. I only work on my own cars. Sorry if I've misinformed you.
Live and learn ....But I still wanna learn more about this.
#15
Just because I'm a curious guy and for others' academic purposes: A comparison of 32V and 40V mounts...one of the reasons I believed them to be similar.
Same body and construction, down to almost every outer detail..other than the valve that opens/closes an air chamber between hydraulic fluid chambers, that softens (open) the mount at idle and creep speed (up to 1100 rpms) on the 40V valve version.
Can't find a diagram anywhere on the 32V mount interior...just called a "hydro-mount" by all suppliers.
On kind of a related side note: Have also found that ETKA does not contain any U.S. model specific info....doesn't even list my engine code and shows the wrong engine & mounts for my year model. Maybe the two stage elctro-hydraulic mounts, definitely on my car (confirmed), were a U.S. market thing on facelift D2's(?)...ETKA shows these type mounts on all D3 (2004 & later) cars.
Look at the similarity (almost identical) here...pics from "redlinemotive.com" :
40V (AUX) mount:
32V (ABZ) mount:
40V (AUX) mount:
32V (ABZ) mount:
#16
Thanks for the great pictures Sam. What version of ETKA are you using? Theres different versions for different countries. If you "acquire" it off the internet you should be able to get the International version. I'll have to see if my ver.7.3 International has US models, being "International" it should. If so I'll send you the link.
By the look of the mount I should only have to undo 3 bolts, and lift the engine enough to get that centre cone out. Much easier than other cars that have the bolts built into the mount, and you have to lift the engine about six inches...which doesnt happen easily.
#17
Regardless of your type of mount, Tozo has a point about the source of the oil on your subframe bushing...on closer investigation, the mount is about 8" inboard of that bushing and mounted lower to the ground. Directly over the bushing are power steering lines and the ABS module...so, don't know.
But your symptoms of clunking and acceleration vibration make me wonder about the mount and other suspension bushings (on upper and lower arms, esp for "clunking")...but all just a guess...curious to see what you discover on closer inspection.
P.S. still very curious about whether described "hydro-mounts" on your car are filled with anything....If you actually change one and it doesn't look breached, do me a favor and stick an ice pick in it, to see if it bleeds hydraulic fluid
Cheers
#18
But, I found that after that experience, I had no trouble adapting quickly during later visits to the UK and NZ...it planted permanent "cookies" in my brain
#19
Ok lads, here's an update.
-I have normal engine mounts...and they arent leaking or appear broken.
-Oil is indeed coming from a slow power steering leak. There was loads of oil sprayed around everywhere on the pipes and back along the subframe mount area, so I degreased all it and will look in a few days to find the source.
-The Bilstein shockabsorber is indeed weeping oil, and the top rubber stop is quite deteriorated.
-The rear-ward bottom control arm is stuffed lol read:clunk clunk.
I was hitting all the joints and bushes with a rubber mallet and they were all just a dull thud, but the bottom rearward balljoint returned a nice *clunk* in all directions I hit it. Also the bush on the body end appears perished (along with several other bushes)
So I've ordered a left and right kit to replace the 4 arms, bushes and balljoints, and will chase up some new front shockies, hopefully Bilsteins wont brake the bank...again lol. A little mifted these ones didnt last longer. I've had standard shock last a lot longer than these and they didnt cost $400each!
Here's some pics of the engine mount, shockie, shockie bush, and my grubby little girl who decided to help.
#20
So quick update....trying to order these front lower arms.
Apparently the A8 FWD and Quattro had different balljoints, and therefor different lower arms.
The most forward lower left arm, where the shock mounts, that I happened to take a photo of had the OEM number 4D0407155F...which appears as a 94-99 A4/S4 ????
Only 4D0407155 *P* (not F) seems to appear as A8Q related.
Any ideas whats going on there? Have my arms been replaced by a previous owner; crash repair maybe, or hopefully just more odd parts on my car from the factory. ie.Gearbox.
I'll give the guy the other 3 numbers tomorrow after I read them off the arms, and hopefully he can match it up to a kit, A8 or not. I really hope so as its only AU$250 delivered for 4 arms, bushes and balljoints included
