code 18032
If not clear then recheck -all should be good :-}
P1624 18032 1 DTC is set: If MIL request signal is
active.
WS/ER Erase DTC-memory, function 05, let engine
idle, check DTC-memory again, function 02,
should not be this fault.
active.
got was telling me to check the TCM had a cable dissconnected to take out the Crank rpm sensor
thanks
thanks
Flats
07-13-2015 11:23 AM
