codes
codes
thanks guys for all the help so far. last night I pulled the codes for my check eng light and came back with a few that I have a question about. 1 code 18020 eng control module incorrect (reads 01273) is this correct for a 97 4.2??? if not what is? also another code 18010 power supply terminal 30 voltage too low.. what is that? and finally the tranny code is 00011. this correct for a non tip tranny? thanks again guys I love this site and the knowledge here..
Probably just an electrical glitch
The corrective action for 18020 is to replace the ECU, but I don't think it's bad....plus you had a low voltage code.
You cleared them, they went away and stayed off....exactly what you should have done....probably nothing.
pw
pw
Yep see this link for description of coding
<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/codingtransmission.html">http://www.audipages.com/Tech_Articles/auto_transmission/codingtransmission.html</a</li></ul>
Re: Yep see this link for description of coding
check eng light came back on. after 50 miles. I guess I will have to buy a vag now. Borrowing one is going to gt old fast. thanks
00002 is the factory code for the 97 non tip. try to recode to 00001 for a better sporty mode.
If you do the tip module thingy like i did, i recoded with 00011, and its much better at the suggestion of Paulw.
rohit13
09-11-2011 03:29 AM
