Codes
Confirmed Trouble Codes
P0441: Evaporative Emission System Incorrect Purge Flow (Powertrain, Generic)
P0304: Cylinder 4 Misfire Detected (Powertrain, Generic)
Pending Trouble Codes
P0321: Ignition/Distributor Engine Speed Input Circuit Range/Performance (Powertrain, Generic)
P1136:
P0321 is a new one for me. Anyone have a tip on what is crapping out on my car?
This is what I found
Causes
Possible causes of OBD code P0321
- Loose wires/connectors - Faulty Crank Position Sensors - Arcing secondary ignition components (coil, wires and plugs) - Low battery charge - Powertrain Control Module (PCM) The Error code is generally activated on detection of the following conditions: The P0321 code is triggered when the signal is out of range.
Possible Solutions
- Resecure loose wire or connectors - If battery charge is low, recharge or replaced battery - Replaced crank position sensor - Replaced starter motor
P1136:
Causes
Possible Solutions
98Quattro
14
07-02-2011 05:59 AM
TwinTurboTerror
9
07-11-2006 04:05 AM
