Common Fuel Line leak location in rear?
Wondering where the most likely leakage point is on the rear fuel lines. My '97 D2 is now exhibiting fuel smell in the cabin in cold mornings.
Previous posts have indicated that the rear (tank) lines have also been known to leak sometimes. I've checked the front lines, both near the FPR (fuel pressure regulator) and closer to the hard lines at the right fender. Both locations look extremely clean- so I doubt I'm seeing leaks there.
Is it usually the (high pressure) banjo fitting that leaks in the back or the lower-pressure return line? Return line has the same type of crimp fittings that have been known to leak on the high-pressure side up front. Both lines appear to be discolored back there, too, so my suspicions are directed to those lines at the moment.
Any ideas, most appreciated.
Thanks,
TT
Thanks,
TT
Call the dealer with your VIN #
My '99 was subject to a recall (which will be performed next week when we travel from coastal Carolina to da' big city). Fuel sender unit o ring and seal.
Service mgr says bring it in with as little fuel in the tank as possible. No charge to perform the recall.
Hope this helps.
Hope this helps.
If you are smelling it in the cabin on cold mornings while driving the car/stopping at a stop light, it's the fuel lines. Just fix them like shown on audipages (with the clamps) and be done with it. It will stop it.
Thanks, Paul. The lines up front all look perfect, though-- can't tell that they are seeping at all. Have others had a a leak on the high-pressure or return lines at the tank?
Wife's complaining a lot-- I'll have to figure it out this week. Front fittings, on both ends, all look great. So, I'm assuming it's the back connections.
It's super dangerous to have fuel leaking in the engine compartment. Just do at least the high pressure line in the engine compartment. Your wife is worth it.
The points are well-taken, but we've examined all the front hoses and fittings very, very thoroughly. We have been unable to find any of the characteristic discoloration or splatter from even a tiny leak up there. I'll send you a PM photo to get your thoughts.
It's clear that there was a leak at some point in the back, where the hardlines come in, though so are focusing there for the moment.
The mechanic specializes in fuel-injection systems, so he is pretty good at sniffing these out. We were both just wondering if anybody had seen other leak locations.
Thanks,
TT
Thanks,
TT
