coolant leak... if it's not the oil cooler leaking.. what else could it be??
what else leaks coolant on the front passenger side of the engine?????
changed out the water pump, which seems to have reduced the coolant leak of about 1/2 gallon per day to about 1/4 gallon per day.
Mine is leaking and the bottom of the radiator is wet. It drips on the passenger side of the radiator. The engine is dry. I suspect it is the hoses going to the radiator and I will know more when I do the timing belts in a few months. The leak is not as drastic as yours.
schranzkt
28
03-04-2016 09:03 PM
MXHowes
03-31-2011 12:56 AM
thegov3
07-27-2009 06:17 PM
Nate (ETKA+Scumbag)
06-04-2007 05:14 PM
