The correct fog light bulb for a pre-facelift A8 is an H3-55W.
I believe there is an H3-100W, is this a stronger bulb?
If I use the 100W what are the pros and cons?
other choices would be better 55w bulbs like the piaa's or 3000k(yellow) hids look sweet. My brother has them in his fogs on his lexus and they look very sharp and contrast the hids really well.
Here:
http://www.rallylights.com/hella/H3.asp<ul><li><a href="http://www.rallylights.com/hella/H3.asp">http://www.rallylights.com/hella/H3.asp</a</li></ul>
will likely fry your electrical system (switches and relays are the most likely points of failure) either immediately or a slow death by cooking. The only way to go to a 100W bulb would be to run a separate (correctly sized) wiring harness to the higher wattage bulb (run off of a relay). Even then the extra heat created by the bulb may melt the reflector in the headlamp housing (they are plastic).
as I have a friend looking for a clean A8 but not sure if you got it. Does the email like from the forum work for you?
<ul><li><a href="http://www.danielsternlighting.com/">http://www.danielsternlighting.com/</a</li></ul>
But the wires will get hot. Not so much from the extra current (even a 22 gauge wire can do 15A or so), but from conduction of the extreme lamp heat down the copper strands.
And we had someone in here last year that melted his reverse lights with a high power bulb.
A4Jared
11-30-2004 01:22 PM
ATH
03-15-2004 02:42 PM
