When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I've had my 1995/96 D2 4.2 4V for a couple of months now. Love the Car!
But recently I started having problems with a misfire on cylinder 3.
I have narrowed it down to the injector (changed plugs, coils and compreession tested)
Only problem i have now is that I can't figure out what injectors to get or where to get them from (preferably EU) the ones on the car seem to be from a 2.8 V6???
And all the ones I can find online only seem to range from 97-99 cars...
Does anyone know the part number for the correct part? and maybe even where I can get them?
Hi, check your ignition module. I had the same problem.
If you switch the 2 and you have a misfire on another coil, it's 100% the ignition module. When I switched mine, I had a misfire on cyl 4 I think.
You will find it in the engine bay, on the passenger side under a plastic cover where the fuel lines enter the bay.
