Correct lube for starter mechanism?
<center><img src="http://i48.photobucket.com/albums/f202/G1968Y/2000_A8_Engine/STARTERA8.jpg"></center><p>I took my starter apart to check the brushes and lube the internals. What is the proper type of lube for this? TIA, Greg
<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/transremovereplace.html">http://www.audipages.com/Tech_Articles/auto_transmission/transremovereplace.html</a</li></ul>
Tozo,
Does your link mean that you actually do have to remove the engine or transmission to remove the starter? If that is the case WOW!!!
Albee
Albee
Not quite. If you look at the procedure, the starter comes out prior to removing the transmission (must be removed to access the TQ bolts). But you do need to drop the subframe and right engine mount bracket.
blackbart
06-12-2021 06:27 PM
OWDLVR
10-28-2004 05:00 PM
