Correct wire to tap into for power?
Almost finished with the LE-30 laser jammer install (will post pics soon). Found a wire that has power with ignition on and no power with it off. System seems to work, but am I messing up anything else? It's the red/blue wire below. This is under and to the left of the steering wheel.
<img src="http://pictureposter.audiworld.com/66776/wiretap_copy.jpg">
Shouldn't you thought of that before you tapped into it?
Sorry, but trying to find that wire in the wiring manaul would be like trying to find a needle in a haystack.
If it's just 12 VDC, I don't think you'll have a problem. If you do, at least you'll know where to start looking.
pw
pw
Sure looks like the wire for the laser jammer to me! 8^)
GrA8 looking car you have there. Do you have a fire extinguisher on board? Oh, you could pull fuses until the power goes off, then consult the wiring diagram for that fuse. Good luck...
Re: Fire extinguisher: check. Fuse puller: check. Wiring diagram: doh!
On my previus car ( VW Golf GTI VR6 )I had the radar detector above the inside rearview mirror. I used the power from the sunroof switch. It has power only in run position.
That's what I'm doing with my Valentine One, but it's only a detector.
By the time it goes off on laser, it's probably too late. The LE-30 actually jams the laser signal. Click on "LE-30 dual" below for more info. The V1 is my choice for radar detection, though.
that is ok
red/blue is generally used for switched/fused power - i believe that that wire is used to provide switched power to the indicator unit.
another way to get this source is off terminal 16 of the dlc connector
jfischetti
05-27-2004 06:43 AM
envuks
05-25-2004 04:43 PM
