Cowl Drain(s)
I have been having some condensation problems when wet weather turns cold here in southwestern Ontario due to water not draining from the cowl area. This weekend I tried in vain to locate the drain hose in the wheel well. Pulled the plastic liner but there wasn't anything under there. The previous owner had to have stored the car outside since there was a large quantity of small leaves and dirt which I have already tried to removed but after pouring water into the cowl area the tubes are still totally blocked and absolutley no water is draining. Does anyone know where the inlet and outlets for the drains are? This has been my only issue with this great vehicle!
1999 Silver A8 Quattro, Cold Weather & Electronics Package
24,000 Miles
24,000 Miles
I don't think you can see the inlets. They're on either side of the front firewall / air intake area.
audipages has a nice procedure for cleaning the AC condensate drains, BTW. This is another common clogged drain problem. Sunroof clogged drains is another.<ul><li><a href="https://forums.audiworld.com/a8/msgs/73973.phtml">Nice pic of the cowl drain here. Thanks Paul!</a></li></ul>
Am I blind or are there any other outlets? I had the wheel off and the plastic liner undone and I just went outside to have another look!!!!!!!
bits of tire, road tar, and leaves. Pinch them .. roll them between your fingers, and water will come bursting out, with the gunk.
CWTech
27
02-12-2015 03:12 AM
brian 4.2
06-16-2003 05:31 PM
gtt
12
12-02-2001 05:36 PM
tlane
11-01-2001 07:48 AM
