Cruise Control
You know I was thinking it was just picky based on previous posts but I know it's broke. It works once in a great while. For a short period of time and then disengages. When it doesn't work it doesn't even try. The few times it does it works great..... breifly. Any ideas?
... harness does not have any water or corrosion. Jack the car up and unplug the switch.
Much of the corrosion in my F125 was from water sitting in the switch. The plug is easy to see from under the car and is easy enough to unplug I would check that first. Remember my F125 switch was affecting my cruise without any doubt.
On my wife's 99 A8Q, we had the exact same problem. We had to bring it back several times under Audi Assured warranty to get it fixed. First time they installed a new turn signal switch which didn't fix the problem. Finally they replaced the Cruise Control Module (4B0-907-305) and associated(?) Repair Kit (4D0-298-135-B) which solved the problem!
Fuzzbeaner
Audi 100 / A6 (C4 Platform)
04-30-2005 07:13 PM
dustin_howell
01-06-2005 07:29 AM
gobble
03-31-2004 11:35 AM
