Sponsored by:
Sponsored by:
Cruise control stops working??? On switch, resume switch nothing happened when I pressed them???
Old 08-15-2004, 09:39 PM
ltooz_a6_a8_q7's Avatar
Default Cruise control stops working??? On switch, resume switch nothing happened when I pressed them???
On the way home tonight @ 65 mph, I tried the cruise control switch, nothing happened. Is there a fuse or something simple? They worked last week.
Old 08-16-2004, 12:56 AM
New Member
BMWho?'s Avatar
mine was broken when i bought it; they had to replace the entire control arm
Old 08-16-2004, 05:03 AM
skiracer's Avatar
Default Look for a vacuum leak to the cruise control controller......
It is on the driver's side just in front of the firewall. Mine had become disconnected and exhibited the same behavior. Reconnected- fixed!
Old 08-16-2004, 08:35 AM
Thanks, I'll check the vacuum leak, hope I don't have to replace the arm!!!
Old 08-19-2004, 08:21 AM
Default I couldn't find the vacuum hose, but I wiggle and press anything that's hanging around the brake
master cylinder and now it works. This is scary, but I can't complain. Thanks Skiracer. Can you take the picture of the part in front to the firewall so I can see.
Thanks,
Seabeast11
08-23-2007 07:28 PM
hanshy5
04-10-2007 06:00 AM
Xameius
04-10-2007 04:22 AM
Quattro 88 80
VAG-COM Discussion
03-08-2006 10:47 AM
NullTerminator
01-01-2003 02:03 PM
Quick Reply: Cruise control stops working??? On switch, resume switch nothing happened when I pressed them???
