CV Boot replace
Gentlemen,
Have any of you fellas changed a front outer CV joint boot on a 2002 A8 and if so is there a workaround for the "special tool" needed to press off the CV joint? Seems to me the procedure is fairly straight forward except fot the need for BILLIONS of special tools.
I like doing some of my own work but the need for all these tools is getting a bit out of hand. Any suggestions?
Thanks,
AlbeeG
Thanks,
AlbeeG
Thanks Tomas,
The article still does not explain how to remove the joint from the axle. I was just wondering if anyone has found a way to do this without the Audi special tool.
AG
AG
just was not worth getting dirty for<ul><li><a href="https://forums.audiworld.com/a8/msgs/160765.phtml">https://forums.audiworld.com/a8/msgs/160765.phtml</a</li></ul>
Which operation are you specifically asking about? Getting the outer joint out of the hub, or getting the outer joint off of the shaft? Or something else?
I don't know what the special tool is.
Assume you mean the outer joint. If there are no external circlips or locks to remove...
1. Clamp the halfshaft in a GOOD vise and use a big brass drift (a foot long) on the inner race to drive it off. Use a big hammer. Or possibly an air hammer on brass. I have an old brass padlock I use. Sometimes trying several spots helps (rotate half shaft in vise.) I ground a half moon in my drift to allow more contact. My drift is 3/4" square.
Another trick is to put a .45 ACP empty or similar on the end of a steel drift.
or,
Use the big allen axle bolt (you took out)to force it off. Keep the joint straight and screw it in hard. . I don't like this method as it loads the ***** but I have used it with an air wrench with no ill effects.
I don't see any reason you could not preload the bolt 20-30 ft /lbs and then beat on the race also.
You are trying to overcome a hidden internal wire circlip, I think.
I have never failed to remove a joint (have done many) but have had to beat the @#$%^ of of some. Full shots with a 32 oz hammer.
or,
After puling the axle out of the car, I put the half shaft in a vise and replaced the axle bolt and tightened it down using an imact wrench. it popped the joint right off.
Jim,
I am trying to remove the CV from the axle to replace the boot.
Thanks to Novice And Gondar for suggestions. I get the procedure now. Love to workaround the damned "special" tools when at all possible. Glad to see others are adventurous.
Thanks All,
AG
Thanks All,
AG
with a needle file, 240 grit paper, etc. (clean off well) and lube with grease before re-assembly. Mark the exact location of the joint on the HS and put it back there, at least I do.
85-4kq-girl
09-20-2006 12:15 PM
RussB
15
03-08-2003 10:08 AM
DavidFeygin
Misc. Models Discussion
12-15-2000 04:30 AM
