CV Boot replacement help!
I am trying to remove the cv joint from the axle and can't figure out where the circlip is that I need to remove is located.
I'll go take a pic of where i am at now.
AKA - hammer. Hold onto the axle stub on the joint while you try to knock the whole joint off the axle shaft. A plastic shot filled hammer is preferred, but steel will do too. Be careful.
While I was trying to fit the axle back into the transmission and hub the gold plate on the back of the inner cv boot that faces the transaxle popped off and leaked brown grease everywhere.
I can't figure out how to put this cap back on and what held it on in the first place!
this is for a 2000 a8l
I put the plate on the inner cv joint back on and installed the axle. The plate is in the correct spot and torqued down with the 6 triple square bolts but it would not stay on if i took the bolts off.
I lost a good amount of grease figuring this out but got it back on.
Do you think the joint will be ok if I just put the car back together and drive it? I don't want to put everything back if I need to do something else.
TIA
TIA
The inner joint needs new grease also.....taking the whole thing apart is a real mess.
Took about 15 minutes total to replace it on a life with Tozo's help.
