D2 '01-S8 - Dead Fuel Pump turns into NIGHTMARE...... (& Member Intro)
#21
Did the noise start after the car sat for a long period (a few days or more)
If so it could be lifters not pumping up.
I would upload a video, that would be helpful.
-Richard
-Richard
#22
i dont think i will be able to get over there tonight but i will try to get a video before it leaves the shop its at now.... prolly gonna end up havin it towed to an Audi Specialist...
#24
My point was that IF a chain pad was gone (loud chain dragging sound) and got quieter, it would indicate that it ate far enough into the tensioner piston to form it's own track. If so, you could loose the seat mount for a new pad...steel chain dragging across soft aluminum (alloy?)seat. Even then I don't think it would go silent...still should be very noisy.
Again, I think the theory of a tensioner being the source of your problem is a reach...only a visual under the valve covers would tell.
#25
Yes I filled the tank with about 5 gallons of new gas..
Ill have to listen for this specifically next time I hear her run. But as you said, and i agree, i dont think this is the source of my the misfires.
#28
Ok so then Im going to put another 10 gallons or so in and clear any codes and start her back up??.......
Should I just let it run... get to operating temperature?? Ive been hesitant to let it run due to how it sounds from misfires.... i guess ill play it by ear on if adding more gas helps clear it up at all.....
