For Dan McBoost!
About that Aluminum dust... I found this post on another Forum.
BE VERY CAUTIOUS USING SCOTCHBRITE TO CLEAN ENGINE PARTS. The
best recommendation is to take any scotchbrite pads you have and hide them away if you even think of working on or near your engine.
Scotchbrite pads are frequently used to clean surfaces of gasket material prior to assembly. Scotchbrite works good for this and seems absolutely harmless yet it is probably the (un-known)
cause of more unsuccessful repairs to engines than anyone realizes.
Scotchbright pads are a nylon substraight with 40 micron aluminum oxide particles embedded in the nylon. Any dust or debris from the scotchbrite will get in the oil and destroy the bearings. Even using scotchbrite on the same work bench and getting the dust on parts is enough.
The failure mode of the scotchbrite is that the aluminum oxide particles get in the oil and get imbedded in the bearing material. The engine runs fine as typically the oil film in the
bearing is greater/thicker than the particle is. If the engine sees high load/high RPM and/or the oil gets hot the bearing film thickness is reduced and now the particle can come into contact
with the crank surface. It sill rapidly machine the cranksurface until the beraing clearance is too great, the bearing pounds out and fails and the owner/mechanic blames the stupid engine. It was really the stupid scotchbrite......
This is so common a failure that the engine re-manufacturers continually run warnings in their publications about the dangers of scotchbrite. If you use it clean the parts thoroughly before assemble and do not use it on deck surfaces or head surfaces at all where it can fall into the coolant jackets or oil passages and not be noticed.
I have personally witnessed MANY engine failures that were eventually traced to aluminum oxide contamination from scotchbrite. It seems so harmless so it is commonly used yet it
it deadly to an engine.
Also after removing the complete masking of my engine bay, and air intake, I then used my air compressor to blow off the entire car.
I am extremely careful with my cars, and myself. This was not my first time polishing parts on a car, and knew of the scotchbrite controversy from the supra forums I frequent. I actually laughed about it, since I was pretty shocked at some of the responses.
Thanks for the heads up. Hopefully this post will save a few problems in future searchings.
The helpful posts such as this, and the lack of flaming is the single reason this forum is the one I spend the most time in.
Thanks Guys!
Thanks Guys!
Potomac-Greg
Mid Atlantic Discussion
22
07-24-2007 12:11 PM
Nate (ETKA+Scumbag)
10-04-2006 09:31 AM
maxh2o
05-04-2006 04:32 PM
Silver Stealth
03-17-2005 09:07 AM
AW #29529
10-01-2002 07:05 AM
