Driver's Side wind noise/turbulence
I have posted about this before and received some helpful stuff but I'm still trying to solve my wind noise/turbulence from the driver's side door area problem on my '01 S8. The problems seems to be getting worse. Had the door checked for alignment -- supposedly perfectly aligned. I'm beginning to believe that the mirror is the issue and I would like to take it apart as there are some threads on the A6 Forum that suggest the problem may be there. Q: Does the interior door panel have to come off to access that rectangular piece that covers the mirror? Anyone have any diagrams, etc., or advice? Thanks.
In any case, here's a<ul><li><a href="https://forums.audiworld.com/a8/msgs/24430.phtml">Front door trim removal thread, with super-high-tech visual aids.</a></li></ul>
mounted inside the door and directly in front of the front door hinges? I can probably imagine a case where wind leaking in here could produce assorted noises.
Jim
Thanks for the diagram. Got a long weekend to try to solve the problem.
