DTC clarification
Have recovered two faults which would like assistance in understanding. (1)Transmission 01192-Torque Converter lock up clutch, 42-00 Speed variation too high;(2) Central Locks, 01374 alarm triggered by terminal 15 , 35-00.
Pls assist
Pls assist
Output on VAS 5051
Possible causes of fault
Fault remedy
01192 P0741
ATF level not OK
Defective or incorrect converter
- Checking and topping up ATF level
Clutch for converter bridging
Mechanical fault in solenoid valve -N94
ATF supply to solenoid valve -N94 not functioning properly
Incorrect control unit fitted
- Read measured value block =>Page 01-36
Speed deviation too great
Electrical activation of solenoid valve -N94 defective
- Carry out fault remedy according to fault code 00270, P1828
01192
1) When selecting measured value block, note what type of hydraulic control the gearbox features. A more detailed description can be found from Page 01-189 => under "Reading measured value block".
Notes on fault recognition of fault code 01192 / P0741:
? Ratio of gearbox speed and gearbox input speed to engine speed not plausible with torque converter lock-up clutch.
dont panic about thre alarm unless it recurrs
Fault remedy
01192 P0741
ATF level not OK
01192
thks for your help again. Where are you getting this info? Should I be able ot source this on VAG-COM? and where are the details for "Carry out fault remedy according to fault code 00270, P1828"? Appreciate your direction so I source thi stuff without going into forum is possible.
many thanks.
many thanks.
upops
10
07-06-2019 04:15 PM
