Electrical confusion
Hi
My automatic head beam control clames malfunction (after exchaning the timing belt). When I switch the head beam on, the horn sounds and no light.
VCDS shows that there is a short circuit or open circuit between the control unit and the adjustment motor.
Well, easy troubleshooting i thougth since i know where the control unit is placed. Just a simple continity and isolation check but NO.
My car is a S8 model year 2000. I have found several electrical schematics showing the same info but it dont match what i see and measure.
Wrong numbers of cables, Wrong color code, no match what so ever when i measure between the connector of the control unit and the connector to the head beam.
Feels like Im trying to troubleshoot an Audi by using a electrical shematics from a Mazda.
I see my self as an pretty skilld "do it my self" both from a electrical and mechanical point of view but this realy beats me.
Any ideas or advices are appreciated
Kind regards Peter
Kind regards Peter
Hi
Kind regards Peter
Kind regards Peter
Oh my...
I discovered that I have switched the connectors for the head beam and the one that goes to the bumber.
Its quite clear now why I got all crazy results when tried to troubleshoot.
Feel a bit ashamed but still happy that I found it
Kind regards Peter
Good that yours was easy to find. I had an experience with a replacement aftermarket wiring harness for a '66 Ford Mustang - the battery would be drained after sitting for a while. Wire by wire I traced out the wires and checked them in the car. Found out that 2 of the wires inside one connector were switched, presumably by the manufacturer of the wiring harness. The feed to the alternator was always hot, leading to a drained battery. Swapped the two and it was fine.
I was very close to open up the harnesk myself but thanks almighty i found the hiccup before that. Mustang 66 , very good looking vehicles but i have no experience of those.
bballfreak
9
04-14-2019 06:59 PM
lmariorod
10-26-2017 11:39 AM
kevjo55
09-30-2015 08:02 AM
