Error codes
Error codes
i did a scan after the transmission rebuid although there were no error codes with teh aut trans there were with the others
Chassis Type: 4D - Audi A8 D2
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76
Address 01 -------------------------------------------------------
Controller: 4D0 907 557 J
Component: 4,2L V8/4V MOTR AT D01
Coding: 03263
Shop #: WSC 02314
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent - ??????
16505 - Throttle Position Sensor (G69): Implausible Signal
P0121 - 35-10 - - - Intermittent - ?????
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 35-10 - - - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4D0 927 156 E
Component: AG4 GETRIEBE 018 D40
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
03-00 - No Signal
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 7680
Coding: 0265109043
Shop #: BB 37680
No fault code found.
Address 08 -------------------------------------------------------
Controller: 4D0 820 043 C
Component: D2-KLIMAVOLLAUTOMAT_D03
Coding: 00180
Shop #: WSC 02314
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4D0 919 033 K
Component: D2-KOMBIINSTRUMENT__D21
Coding: 00183
Shop #: WSC 01588
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to B+ - Intermittent
Coding: 03263
Shop #: WSC 02314
4 Faults Found:
Readiness: N/A
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
03-00 - No Signal
Coding: 0265109043
Shop #: BB 37680
Coding: 00180
Shop #: WSC 02314
Coding: 00183
Shop #: WSC 01588
1 Fault Found:
Dont panic about those codes they are
probably those not cleared by the mechanic who worked on the car.
Clear these and see if they reappear.
Unlikely to do so.
The fuel level sensor included
Suggest you do a basic settings in the measuring blocks to reset defaults.
then let everthing re learn
It may even be the same for the transmission.
Check with the tech who worked on it first so not to stuff up any recorse on work done to date.
Good luck
Unlikely to do so.
Good luck
Nate (ETKA+Scumbag)
01-31-2007 03:36 PM
