Sponsored by:
Sponsored by:
Fan Bearing? Help? No aftermarket part available.
Old 02-02-2012, 03:58 AM
  #11
ThaboTheWuff's Avatar
Originally Posted by Adjuster
It's just my 1998 A8 was a belt driven fan with a fan clutch, and my 2004 A8L has only electric fans.
I also realize you can't just run two fans off the controller, thus, using only the fan power to trip the relay, and use at least a 30 amp relay, wired into a source of main power, with it's own seperate fuse and ground.
I agree that most mechanical fans do a great job, but if the bearing is xx.xx dollars to replace, and a large electric fan, relay and fuse is less, why not try the DC fan? (I know of a kit that is sold with two fan sizes available using this same setup for the most part.)
I would only consider hooking up to a fan that is not dependent on the AC system to get a signal to work.
On cold days, my current ride does not run the DC fans much at all, but on hot days, it sounds like a 737 on take off at times, and the "wind down" noise after shutting of the engine is classic large fans spooling down.
A big advantage is at speed, the DC fans are not needed for 99% of the time, so you are not dealing with the drag on the engine, or the alternator.
I would only consider this if the bearing was not needed however. If you need the bearing there for the fan, just to have the belt turn a now empty pully, it defeats the purpose too.
Just thinking outloud here, and I have seen some aplications where DC fans do not work nearly as well as the OEM fan/clutch setup.
It turned out that my fan was fine, the bearing on the pulley that was attached to it is the problem and that's a $430 item if you don't pull it apart and get just the bearing part. Agree with you, electric fan is better and I actually have a new electric fan but it too is noisy, not sure why, perhaps in the cost cutting electric fans are cheaper built, cheaper bearings who know. I am now at the point where I have to decide if I want to replace the tensioners too as if you look at my video they appear to be loose but perhaps this is how they are mean't to be?
L Cubi Rivera
05-21-2018 05:47 PM
BlueB5
01-29-2007 09:12 AM
bzientek
Audi Original "S" Cars
10-07-2006 05:19 PM
Old91CivicGuy
06-14-2006 12:42 PM
Quattrotrac
06-20-2005 11:40 AM
Quick Reply: Fan Bearing? Help? No aftermarket part available.
