Fan not turning on after the car is turned off.
I have noticed over the past two days that my fan is not turning on after the car is turned off. The engine is warm and becomes excessively hot after the engine is shut off. Any ideas. can this be fixed by vag, or is my thermo shot?
It shouldn't be running when the car is turned off, did you open the hood and verify this?
How long does it run?
open. Other then that, Nromally I notice a fan kick on after I turn the car off, on a hot day or a long drive. I have a feeling these recent problems are all signs for my TB/WP/Thermo change. I had the hood up two nigths ago and the engine seemed hotter then average.
The electric one on the side of the main fan. its happened to me too and the engine is very hot when you try to open the hood.
You can start it manually after the engine starts by tappign on the motor or pushing the fins by hand quickly and legging go (BE CAREFUL)
My mech. talls me taht tah carbon has worn out and cant really be fixed therefore it has to be replaced.
Although if it is the main fan then its probbaly the fan clutch.
i wont be surprised if both failed becasue it has happened on mine.
The three relays for the three speeds of the electric radiator fan get coil power only with the key on. Unless somebody added an after run modification, if the fan runs with the car off, one of the relays has stuck or something else is wrong, and there is no guarantee that the fan will shut off before running down the battery.
Tom
Tom
NigelC
05-07-2011 11:29 AM
Tulipo
02-17-2005 10:12 AM
We need to develop a mod to run the AC fan for a few minutes after engine shutdown to lower engine..
jetboy737
08-07-2000 04:38 PM
