Fault codes for steering wheel
I posted a few days ago about my steering wheel issue and the airbag light. I told the dealer that all my functions on the steering wheel are not working ( NO heated function, No Tiptronic control, No radio, No horn. ) The airbag light is also on in the guage cluster. I tried to convince him it was the clockspring but he could not confirm that from the codes he pulled. If anyone has any insight into this please let me know. The codes are ( hope I copied them correctly )
00588 Driver Airbag + 95 resistance too high
01426 Operation Unit in steering wheel no communication.
Thanks
Thanks
Those codes would point me DIRECTLY to the clock spring! It's the only common....
failure point I'm aware of for those two components. Plus, the clock spring is a known weak-link in the Audi.
Sent you a sheet=what controller did the second cosde come from?
The first does point at the spring or a loose wire.
As every other thing is failing check your earths?
VAG1551 printout
Possible cause
Possible effects
Corrective action
00588
(DTC 00588 continued)
Airbag igniter, driver's side -N95
Resistance value too low
? Damaged wire
? * Igniter for driver's airbag not triggered.
? Repair damaged wire.
? Self-cancelling ring with coil connector and slip ring faulty
? Check self-cancelling ring with coil connector and slip ring
=> Repair Manual, Body Interior, Repair Group 69; Servicing airbag III and V; Removing and installing self-cancelling ring with coil connector and slip ring
? Driver's airbag unit faulty
? Replace driver's airbag unit
? Airbag control module faulty.
? Replace airbag control module
VAG1551 printout
Possible cause
Possible effects
Corrective action
00588
? Damaged wire
Re: Sent you a sheet=what controller did the second cosde come from?
Hey, thanks. I appreciate the effort you went to. This is what makes this forum great. I will update you on the outcome.
Mark US-V8
02-05-2009 06:18 AM
tennisjock
TT (Mk2) Discussion
12-30-2008 06:19 PM
Kenghh
05-14-2008 01:37 PM
Pre95
12
01-26-2008 06:25 PM
quattro100
12-27-2005 02:52 PM
