FEELER: 1998 A8 4.2Q Ming Blue/Gray 108K
<center><img src="http://pictureposter.audiworld.com/60058/dscn2186.jpg"></center><p>So I am tossing the idea around of selling my beloved D2.
Here's the specs:
1998 4.2L Quattro
108,250 miles
Ming Blue
Gray Leather
Cold package (heated seats (4)), ski boot
Condition:
Ext. - 7.5/8-10 - your usual nicks and scratches. there are some scratches on the rear doors from what looks like a run in with the car carrier but most buff out with a good wax...im sure they can buff out completely with the right detail work. front bumper was repainted and lower valance was color matched.
Int. - 8/10 - no rips/tears in leather. carpets are very very clean, no stains or scratches. there is a little leather creasing in the driver seat but not too bad.
Service:
NGK iridiums @ 75K
2 power output stages
3 Motor mounts
2 Transmission mounts
Main drive shaft
ECU
TCU
(all of the above were replaced while chasing what ultimately was a misaligned timing belt by the previous owner)
consistent 5k oil changes w/ 0w40 Mobile 1
Tozo'ed Throttle Position Sensor
Transmission @87K (still has 6mo/5000miles on the warranty)
Water pump
Idler pulley
serp belt
2 Cam seals
Timing Belt (once at 75K and again at 108K due to cam seals blowing out and spewing oil all over the TB).
Plate behind the TB housing on pass. side(not sure its proper name) due to a crack causing an oil leak.
Mods:
35% tint
Denison IceLink iPod Integration in cup holder
OEM clear corners
LED parking lights (lower grille strips)
Lower grille facelift update
18" RS4 reps custom painted gray with Carbon Fiber Center caps w/ Bridgestone RE050s (probably wont go with the car but I can be talked into it)
LLTek Intake
stubby antenna
I'd like to ask $5-6K for it so please email with with any additional questions. More pix available via email.
Thanks
Andy
Here's the specs:
1998 4.2L Quattro
108,250 miles
Ming Blue
Gray Leather
Condition:
Service:
NGK iridiums @ 75K
3 Motor mounts
Main drive shaft
ECU
TCU
Water pump
Idler pulley
serp belt
2 Cam seals
Mods:
35% tint
OEM clear corners
LLTek Intake
stubby antenna
Thanks
Andy
Audi Other 1995 Urs6 Europa Blue/Ecru $4900 Chicago
TJT
05-02-2015 11:50 AM
bagwell
13
03-05-2012 08:45 PM
'01 S4 Kid
04-04-2006 07:55 AM
