front diff
I went to go chang my front diff fluid and it is BONE DRY. No oil at all in it. I don't see any oil leaks. The diff is not manking any BAD noise.. No whining, grinding etc.. seems to engage still in awd when needed. I filled it now, but how cold that of happened. God knows how long it has been like that. Any know causes for fluid leak to look for? Has anyone else had this issue... thanks
Our AWD is full time 4 wheel drive. There is a little oil pipe in the tranny next to the valve body that has gear oil to lube an inner drive shaft bearing. If it leaks, you can lose gear oil, but it is highly unlikely, you would have very bad shifting problems. Oil can leak trough the differential seals more likely.
noise. I believe it requies enough fluid not to. I think even with it being very low you would here some grinding/squealing.
had a big sale locally.. Changed the rear and front. He said that when he pulled the plug to fill nothing came out. I have not done this myself yet or really looked at it to see how procedure is done. But Like I said the car is fine and never had any issues with the front diff.. I am sure I am fine.. I will keep a eye on it and look for leaks. Right now the car is laid up looking for a new axle assembly.. Also need a new bolt for the upper control arms bracket. the bolt snapped off while trying to loosen it.
they don't come in any of the kits that I've seen out there. If you don't have them, they're guaranteed to be stripped, seized or break. Of course if you do get them, you probably won't need them ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Bob
Bob
I followed the instructions according to bently, I did not see your post on this before. Oh well just another thing I have learned about with this fun car..
am_ver
10-22-2013 11:37 AM
Merkin
07-28-2005 08:42 PM
4eight
07-18-2004 08:09 AM
