Fuel filter replacement
It's pretty easy to find and replace compared to some other Audis. In front of the passenger wheel well there is a plastic cover. Remove it and you will see the filter. Get a drain pan and loosen the banjo bolts while holding the end of the filter with an open end wrench. (Don't lie directly under the filter, some fuel will drain out). Then undo the strap. Don't forget to replace the crush washers when reassembling. Before putting the cover on, start the car to check for leaks.
AudiS4play
11
01-18-2009 02:36 PM
ivansis
9
12-22-2008 06:43 PM
UrSoccer_mobileĀ®
09-14-2002 02:32 AM
Spanglear
15
10-10-2001 04:29 PM
