Fuel Pump Replacement Follow-up
I'd promised to post the internal part number off the fuel pump we'd recently replaced on the '97 D2 A8Q 4.2L.
The fuel delivery assembly actually snaps apart pretty easily-- it's a wonder of German plastics fabrication. At its core, though, looks like a stock VDO pump.
It has an embossed 4-Ring logo on the side, but has VDO markings all over it:
VDO part number 4D0906091
I think this matches the part number posted recently by another member for the pump out of a 1998 D2, as well.
I'm going to order a new pump to repair this unit as a spare.
As the weather gets colder,
the heated seats are feeling even better!
TT
TT
So to get this correct, has anybody ordered just the pump/motor combination, sucsessfully recieved it, installed it and it works?
Paul,
Not yet, but I'll go ahead and order from the online source posted before, re-assembly, install and report back. All three of my D2s have over 130K on them, so I'm thinking I'll start carrying a spare in the trunk.
Gabor indicated he'd changed his in a parking lot during a trip in not much time, out of necessity, so it's probably reasonable to have a spare on hand. It looks like these things aren't good for 500K miles and, like the TB, can fail at a most inopportune time.
I replaced mine and I'm having problems with fuel pick-up. After fill-up I can only travel 7 gallons worth then the car runs out of fuel even though there is 3/4 of a tank left. I'm in the process of disassembling and reassembling according to the Bentley (to the letter).
The pump works fine, starts and runs great. My issues as you may already know stem from fuel not getting to the pump after 7 gallons of use.<ul><li><a href="http://www.autohausaz.com/search/product.aspx?sid=h0iqtvzk3dbspx3zyzh34sjr&part number=8A0906091G">http://www.autohausaz.com/search/product.aspx?sid=h0iqtvzk3dbspx3zyzh34sjr&part number=8A0906091G</a</li></ul>
http://www.worldcarparts.co.uk/tabid...5/Default.aspx
Same issue here in UK as well regarding only the whole assembly being available from the main dealer
Zumkopf
08-15-2018 06:02 AM
