fuel pump - tank question
I was debating whether I want to swap the pump with 3/4 of fuel when I had this thought...
Is there any overflow from one side of the tank to the other?
I know it's setup to pump when the car is running. I just don't remember how high the middle was. If it doesn't naturally overflow, maybe my fuel issue is cut in half, or at least it's less.
If I can get away with siphoning 7-8 gallons from the right side that's not so bad.
If I follow that thinking, does that also mean below 1/2 tank the right side (where the pump is located) should be basically empty? I know the two side aren't identical so maybe it's not exactly "1/2".
Bob
Bob
