Fuel Rail
Likely an o-ring. Is it leaking from an injector or the metal rail itself?
The fuel rail is easy to remove, I'd start by replacing all the o-rings if the leak point isn't obvious. Also, the mechanical connection of the fuel line to the fuel rail is a common leak point, especially when it is cold out.
Re: Likely an o-ring. Is it leaking from an injector or the metal rail itself?
It's been cold here...so that the fuel line to rail junction is likely. Thanks for your help.
oyama
09-16-2011 07:51 PM
acmathis61
01-28-2007 04:01 PM
HOPSBurner
Chicago Discussion
07-15-2005 01:53 PM
