got CEL light last night, pulled engine codes, Help with interpretation please
So on the Way to the movies last night (25mile drive!) Got a CEL on the '97 A8
Pulled the engine codes and got this.
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-10 - - - Intermittent
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
I just replaced the batt a few weeks ago I guess thats where the first one came from.
So what could be causing these Errors?
Thanks
Britt
4 Faults Found:
Thanks
Britt
This can cause the lean codes you're seeing. It could also be the MAF itself- they do go bad over time.
with your intake/fuel injection system. I would start by running a full tank of gas with 2 large bottles of Techron in it to clean the injectors, and also check for air leaks in the intake- check all the hose clamps and other fittings for leaks. Then I'd have the MAF checked out. There are several sensors that could be out of spec as well and not throw codes.
even with older type cars.
I had the same with an old 1953 Desoto years ago.
The carb bowl worked loose.
Also scan the o2 sensors to see they are working efficiently.
I can do the checking myself.
I did save a few min of driving last night with VAG com. Anyone care to take a look at the xls file?<ul><li><a href="http://www.brittcrowell.com/a8/a8vag.xls">XLS of VAGCOM driving - 63kB .xls</a></li></ul>
