have not gottent he power bleeder yet, how much should some one charge to change the break fluid? Or
I'll have mine with me
It should be about $100 to change the fluid if you have somebody else do it.
I've changed three cars in the past four weeks and really don't want to change another. I will stand up and pump up the bleeder and fill the resevoir for you....but you'll have to take the wheels off, hook up the hose, do the valves and dispose of the fluid.
I will be doing the track day on Friday day....then will be back at the hotel around 5....
I also have the 11mm flare wrench with me. You just need fluid.
one-man bleeder $8 at pep boys
This is the kind that you hook onto the bleed valve and then go sit in the car and pump the pedal. But if you marry it to a manual vacuum pump then you have a vacuum bleeder. Autozone loans out vacuum pumps for free, afaik, and they sell a couple of interesting brake bleeder gizmos for under $10 too.
rocketman4321
04-18-2010 10:52 PM
tomek
04-08-2007 04:48 PM
GIAudi
02-12-2007 03:32 PM
