Sponsored by:
Sponsored by:
headlight lense refurbishing
Old 07-25-2005, 07:57 PM
awdinut's Avatar
Default headlight lense refurbishing
I wetsanded my facelift plastic headlight covers and tried to polish them back to clear with an edge wheel pad on a drill and red rouge compound stick. I was unable to get the lens back to clear...what step did I omit?
Old 07-25-2005, 09:01 PM
Dan McBoost's Avatar
Finding new lens.
Old 07-26-2005, 04:52 AM
ex-a8drifter's Avatar
I dunno if the drill is fast enough. I think you can take it to a glass place to have it buffed.
Old 07-26-2005, 05:03 AM
A8CT's Avatar
Default what grit did you use ? When I did mine, I started with 240 and went all the way up...
to 2000 with about 5 in between. At that point, I used heavy, med, fine, swirl remover. A lot of steps but it works. Don't worry, the plastic is pretty thick. Worst case is you start over. Go to school on one side and then you'll have a system for the other.
Bob
Old 07-26-2005, 05:09 AM
A8CT's Avatar
agree with that. I have the small Porter Cable buffer which did a nice job
Old 07-26-2005, 04:55 PM
awdinut's Avatar
Default Re: what grit did you use ? When I did mine, I started with 240 and went all the way up...
I ended with 1500 grit but I did not use swirl remover but I will do that. I have seen swirlremover but never in various 'weights', what brand did you use? And was a drill and rouge sufficient to end with and achieve a perfectly clear lens?
a_very_naudi_guy
11-25-2018 09:43 PM
therealman
10
08-29-2012 07:11 AM
ccsocop
05-02-2010 05:42 AM
richmond5
10-06-2008 06:28 AM
Quick Reply: headlight lense refurbishing
