Help: Glove box lock removal?
Service and Repair
Special tools and equipment
Precision mechanic screwdriver; 1.6 x 40 mm
Turn vehicle key approx. 45° (-a-).
<img src="http://pictureposter.audiworld.com/75069/91427060.jpg">
Insert precision screwdriver into hole (arrow).
<img src="http://pictureposter.audiworld.com/75069/91427061.jpg">
Lock screwdriver into guide tab (arrow).
Press guide tab upward. Lock cylinder is unlocked (if necessary, correct key position slightly).
Pull out lock cylinder with vehicle key inserted.
It may take a bit of jiggling to push up the retaining tab, but once you get it, the lock should slide out very easily
the following pic are for removal of the push button too...
<img src="http://pictureposter.audiworld.com/75069/91427062.jpg">
Loosen screw (arrow) through hole for lock cylinder until retaining bracket slides back.
Remove push button from front.
<img src="http://pictureposter.audiworld.com/75069/91427063.jpg">
BTW did you sort the noise issue you had? Was it the cat? you would easily smell it if it were the cat's, I'd say! or might be the heat sheild (I had the same problem with me Rustang 5.0. I am not sure this bugger's got one). Anyways hope you found the cause, let us know.
This is what the EPA says with respect to the cats 80000 miles or 8 years
www.epa.gov/otaq/cert/factshts/catcvrts.pdf
reads "PTY D FUL" ? Cabbage launching motar in the trunk cobbled together from left over tractor parts...Clearly on a mission to right wrongdoing, whilst avoiding military intelligence agents ......In a driveway right now, sure, but at any moment now......
This is what the EPA says with respect to the cats... 80000 miles or 8 years
eman
A4 (B8 Platform) Discussion
01-07-2009 06:36 PM
bhz1
02-15-2007 11:44 AM
Oo.et.oO
03-25-2005 05:10 AM
