Help!!! Tranny went into limp mode tonight. This happened once before and I restarted the car
and it fixed it. This time, I was coasting a bit forward before I shifted into reverse and the error mode flipped on! I turned the car off and restarted and the tranny is still in limp mode. Please help!
Try disconnecting the battery for + 15 mins.
That sould reset the tranny learning. Hope that helps...
Not sure about the coding, but it might be good to collect data on evtl. problems after recode.
If the gear indicators on the dash work
it can be interrogated, if not the J217 is not functioning at all, i.e. it cannot be interrogated via VAG-COM.
But as said, taking the power off for at least 15 minutes should reset the unit. Maybe that fixes things. (mind the radio code!)
