Heres the "official Audi" line on my HVAC problem.
#12
example, set your thermo to X temp. and then hold a thermometer 6" away from your rear door vents (or whatever). Let us know your control tests and we will all do the same tests in our 04's. Happy to help. . . build a case. . . .and then dig up Perry Mason since you might have a conflict of interest, or not.
#14
and regardless of what the front was set at the rear only could muster up 66 degrees. Have your front center vents ever blown cooler than the outer ones?
#17
When the Bently comes out, I'll be able to figure it out for you, or when I get my new Ross-Tech cable in a month or so.
What losers......
What losers......
#18
The lack of knowlege by AOA is frustrating. I wonder if the ducting is such that it can't provide heat (air from the AC only). Or if the ducting is such that it could send heated air, but software control is preventing it....
Anyone have any schematics of the HVAC system of the new A8's?
#19
<ul><li><a href="http://www.bentleypublishers.com/product.htm?code=AD34&subject=2">And I appear to be correct: 'Available June 1, 2004' - Anyone want to take bets on them making the date? The history isn't good.</a></li></ul>
#20
than the outer ones is actually a 'feature' in our cars. In the HVAC setup menu, there is a choice for how much cooler/warmer you want the center vents to blow vs. the outers...check it out.
