here's a new one to me. no start??
I went to lunch today after driving all morning and when I came out to leave, no start. All my electronics work, no new fault codes, nothing. But my car wouldnt start, it wouldnt even turn over. WTF? any ideas? anyone have this happen to them?
First put your car in N and try to start it. If it starts, then you know it is just a cable alignment problem. Put your car in park and loosen the two cable adjuster bolts to relieve tension from the cable.
If it doesn't start in neutral, then check the ignition switch. <img src="http://pictureposter.audiworld.com/80919/5hp24a.jpg"><ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/f125switchreplace.html">http://www.audipages.com/Tech_Articles/auto_transmission/f125switchreplace.html</a</li></ul>
He said the engine is not turning over, not that it's turning over and not starting. It's the neutral safety or his battery is very weak.
Of course Tozo raises a good point about the ignition switch.
I'm still betting on "move shifter around, and it starts fine."
Common problem for A8.
If you take out front right wheel, you can see small box with cover. It is connection. Cooper wire connect with aluminium body. Rust to green powder very quickly.
