How much would you pay for your AC system to be evacuated and recharged?
#11
Thanks, but I would rather evacuate the system and then recharge the right amount. I think it's the best way to go.
pw
pw
#12
and gauge attached - about $20. Will these work on the A8 ? I thought someone a while back said the charge port wasn't accessible. If it is, give shot. Its worked 6 mos for me and I was basically blowing lukewarm air.
#16
One of the smartest things I ever did was buy a small Robinaire vacuum pump. This was 20 years ago. I had to buy a new one but there are now all sorts of cheap-ish pumps on ebay. You need a quart of pump oil, too.
I have used it many times, and have loaned it many more times times. You get a much better job letting the pump run overnight which you can do if you have one. I just had a new five ton R22 system installed in my home and I put my pump on it all night so I know the system is dead-dry. The technician thought this was excellent practice.
After you pump a car down you can charge slowly into either high or low sides, with the engine off, using temperature differential and a scale. Just make sure you don't liquid lock the compressor becasue it is a vapor pump, not a liquid pump.
I have one car that seems to have only a low pressure port for R134a, I have added little twice but never had to pump it down.
iconoclast
05-20-2007 09:58 AM
lolyf
04-17-2006 06:31 PM
matt13
07-08-2004 06:14 AM
Hokie - STI avant
06-23-2003 04:10 PM
