How pure does the trans fluid have to be?
Picking up my transmission saga: oil analysis showed contamination of the trans fluid by water but not antifreeze, leading me to suspect that the radiator was fine but water infiltrated while the trans pan was loosely attached. There’s no easy way to completely drain the transmission - the pan only holds about a gallon, the whole system holds three, and the upper radiator cooler hose is too small to pour enough fluid in to flush the torque converter. So I hit on the idea of doing several standard drain/fill cycles. If I do six, if there were a quart of water in the system to start with, would dilute it to about two ounces. Is that good enough? I figure I probably couldn’t do much better even with a pro machine flush.
Zumkopf
1998 A8Q 143k
Zumkopf
1998 A8Q 143k
Should be fine. That residual two ounces should slowly evaporate out of the ATF and out through the vents on top of the transmission housing (assisted by heat from the warmed up fluid).
A6George
Audi 100 / A6 (C4 Platform)
03-13-2008 07:13 AM
kday
01-14-2007 04:36 PM
