I need some help. It looks like the 02' A8 has 2 cats/side. Can anyone confirm it for me?
The downpipe from the manifold to the cat usually just a pipe. I am working on an 02' and the o2 sensor is before the cat. I've looked up there is a cat looking thing. I don't have ETKA here in the shop. Thanks!
I'm looking at Bentley on eBahn. From the exhaust manifold, the exhaust pipe does have a broader element mid-pipe, after the O2 sensor, then mates to the cat itself. Not clear if that is just insulation or if it's a pre-cat like some GM cars use.
I'll send you a PDF of the system on PM right now.
That down pipe is a pre-cat and it has the o2 sensor front of it. It goes down just like the other years and after the flange is the cat converter.
<img src="http://pictureposter.audiworld.com/80919/imag0020.jpg">
The after cat o2 sensor is right front of the cat not after like the older ones.
<img src="http://pictureposter.audiworld.com/80919/imag0021.jpg">
as separate components. The right side has the pipe and TWC as one unit. Are you thinking the "bulge" upstream of the TWC is a pre-cat converter?
