Installed my Tozo'd TPS lastnight...still having some issues
There is a noticeable difference in taking on a hill at 30-45 now. I don't get the obvious shift between gears as before, but it still doesn't feel like it's shifting correctly. I gave a little throttle from about 15mph this morning and it felt like it skipped a gear when upshifting, then the higher gear "chattered" - that's the only way I can explain how it felt. I let off the throttle, then depressed again, and it was gone. Any Ideas?
then i bitched up my TB gasket and had to buy another one! just make sure when you install it that you position it at the "clicking point"
-ignition on and car not running
-slowly push gas pedal to floor over 15-20sec, hold for 5-10, release slowly over 15-20sec
-turn car off for 2-3min
whether or not it's on a hill or not...it feels like it's momentarily dropping out of lockup between each gear. It didn't do this prior to the new TPS. Is this expected as it learns?
