Instrument cluster intermittent failure
I've lived with this problem for many years but now I'm thinking to tackle it. at random times while driving, my instrument cluster loses power entirely. This is not just the dead pixels, tach and speedo go to 0 as well. Every comes back up a few seconds later, and the clock resets to 12 am 1/1/1999
So, has anyone else seen this problem or attempted a fix?
Thanks for the reply Tozo. You must have tiny hands, if you can do that in 10 minutes ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I've done it a few times now, no real change in behavior, everything looks fine. I'm beginning to think ground connection. are the grounds all over behind the glove box?
I just had the exact same problem with my 2000 TT. I have been living with it for several months. Tried pulling the cluster, cleaning the contacts, etc, but the problem would come back.
Read yesterday to try pull fuse 11 and 15, so I yanked them out waited a few minutes, put them back in, and guess what......everything is back to normal. I just had to wiggle fuse 11 with the engine running and it seems to fix it. I can't say how long it will last, but it is worth a try.
Al
Al
The only fuse I have listed for instrument cluster (wheel functions, park sensors, trip computer included) is #1 in the Yellow row 15amp (3rd row)...other than a seperate one for cluster illumination 5amp(#3 Red..2nd row).
Don't know if you have the same fuse block, though(?) ...mine's an '01 A8.
Both 11 and 15 say instruments.
I originally found 15 labeled instruments, and checked it but it was OK. I just read yesterday that there are two fuses. For me 11 did the trick.
al
al
Thanks, but A8 has completely different fuse arrangement...5 rows, colored coded...plus another fuse block in the trunk.
Jery
06-01-2009 02:48 AM
DuckMcF
10
05-02-2005 08:51 PM
Koushik
09-05-2002 11:38 AM
