Sponsored by:
Sponsored by:
instrument cluster wiring diagram
Old 04-07-2004, 01:35 PM
cj750rock's Avatar
Default instrument cluster wiring diagram
does any one have it?
Old 04-07-2004, 03:10 PM
PaulW's Avatar
Sure, what specifically do you need?
Old 04-07-2004, 08:13 PM
cj750rock's Avatar
Default I have an issue with....
my new instrument cluster. How does the automatic lighting (numbers) level adjustment work? Do your numbers light up when it gets dark?
Old 04-08-2004, 07:36 AM
PaulW's Avatar
Default Does yours light up during the day?
It should light up during the day and night....the schematics won't show anything for that....if it is not light up during the day....something is wrong.
Bring it back to the dealer and tell them to fix it.
Paul
Old 04-08-2004, 07:50 AM
cj750rock's Avatar
Default Re: Does yours light up during the day?
It does but if I drive under a tunnel or a parking structure, it goes dark. The dealer is saying that it is supposed to do that and that my old cluster may have not worked properly.
Old 04-08-2004, 08:39 AM
PaulW's Avatar
Default They are wrong
It should light up and stay on all the time. Check out any A8 out there.....every single one of them works the same way.
So you are saying that it's normally on, but if you go into a tunnel during the day with the headlights off, the dash lights turn off? Well, that's really wrong.....
I will check the Bently and see if it has an adaptation for it.
pw
Old 04-08-2004, 09:22 AM
PaulW's Avatar
Default Here's the things that need to be adapted
Check out the list....it's not a short one....
Input values for replacing instrument cluster
The following must always be observed when replacing the instrument cluster:
Notes:
Instrument cluster must always be coded.
Note the values indicated in measuring value blocks 10 - 15 on the VAG1551 scan tool before replacing.
Adaptation channels 42 - 44 must not be transferred to the new instrument cluster.
Note odometer reading before replacing and input according to instructions.
In countries with speedometers calibrated in miles, adaptation of the Service Reminder Indicator (SRI) can be performed in miles.
01-107
Perform the following steps after replacing instrument cluster
- Code Control Module page 01-32 .
and
- Carry out adaptation of fuel gauge page 01-62 (for altered fixed value).
- Language version of driver information display page 01-65 .
- Adaptation of auxiliary heater page 01-74 .
- Adaptation of fuel gauge sender resistance range page 01-77 (for altered fixed value).
- Adaptation for distance driven since service page01-80 .
- Adaptation for time since service page 01-82 .
01-108
- Adaptation for oil quality page 01-93 .
- Adaptation for total consumption quantity page 01-95 .
- Adaptation power train data-BUS page 01-97 .
- Adaptation power train data-BUS page 01-100 .
- Adaptation information data-BUS page 01-103 .
and
- Adapting odometer page 01-70 .
- Adapting immobilizer after replacing instrument cluster page 01-155 .
- Adapting vehicle key page 01-146 .
Old 04-08-2004, 04:42 PM
cj750rock's Avatar
Default Yep. that is what it is doing
The dealer called this afternoon and told me that hey will take the car back and fix it. They are way too busy and they will call me with a date.
Old 04-08-2004, 04:44 PM
cj750rock's Avatar
Default Re: They are wrong
There is a light sensor on the bottom right side of the tech. I flashed it with the flash light and it sure works backwards.
Old 04-08-2004, 04:57 PM
PaulW's Avatar
Default Make sure you bring all of your keys in too
If you didn't give them all your keys when they put the first one in, only the key or keys that you gave them will work in the car due to the immobilizer.
Quick Reply: instrument cluster wiring diagram
