interesting article in "the times" about used a8's
<ul><li><a href="http://www.timesonline.co.uk/article/0,,588-756698,00.html">http://www.timesonline.co.uk/article/0,,588-756698,00.html</a</li></ul>
I assume it's the corrosion that could result from bolting a steel tow package to the A8's aluminum frame. To be done properly, rubber gaskets are used to keep the bolts/fasteners from electrically connecting the steel and aluminum ... a bit tricky.
Range Rover's often have a corrosion problem under the hood where the aluminum body bolts to the steel fender.
cause contact corrosion? Or even the tow bar unless you leave it permanently installed? The only reasonable way to get contact corrosion on these vehicles is to use incorrect fasteners when reassembling the aluminum components, and leaving them installed for a considerable period of time. Other than that nit, great article!
Redneck Truck
03-15-2010 04:45 AM
germantoy
Audi Original "S" Cars
02-24-2006 10:55 AM
SecureS4
08-11-2005 02:03 PM
BCris69
07-20-2005 05:14 PM
